CSV - bulk import
CSV - bulk import
Сообщение MontoyaSat » 30 мар 2025, 22:11
I need a bulk import using CSV
Simple importing of description
LAT,LON,NAME,DESC
49.42694166,21.69508611,abc,ggg
49.42694166,21.69508611,abd,gggfgg
Does CSV allow such a comprehensive Placemark description?
Example Placemark Description
<b>
<h2>ele: 400.58</h2>
<h2>ele:bpv 000.58</h2>
<h2>Prominence 100.58</h2>
<a href="">OSM</a><BR>
<a href="">PEAKFINDER</a><BR>
<a href="">ZBGIS</a><BR>
</b>
<BR>
<img src="V:\0.jpg"/>
<BR>
Thanks for an example of such import :mrgreen:
MontoyaSat
Re: CSV - bulk import
Сообщение mate » 31 мар 2025, 10:33
Try this:
LAT,LON,NAME,DESC
49.42694166,21.69508611,abc,<b><h2>ele: 400.58</h2><h2>ele:bpv 000.58</h2><h2>Prominence 100.58</h2><a href="">OSM</a><BR><a href="">PEAKFINDER</a><BR><a href="">ZBGIS</a><BR></b><BR><img src="V:\0.jpg"/><BR>
The Description text should not contain commas, as they are used as field delimiters in the CSV.
mate
Сообщение MontoyaSat » 01 апр 2025, 12:19
Why SaS adds to the "NAME/DESC" description when LAT/LON, does not add.
I will have to manually erase it.
you can do it to not add it,
or I have to write it on mantis.
MontoyaSat
