gps track colour
gps track colour
Сообщение zazu » 04 ноя 2020, 15:28
Hi dear
Is it possible to change the color of GPS tack in SAS planet software
Regards
Zazu
zazu
Re: gps track colour
Сообщение vlasto1 » 04 ноя 2020, 17:12
Так.
vlasto1
Сообщение zazu » 04 ноя 2020, 18:30
thanks for the quick reply
"actually I want to plot the GPS data from a vehicle in real time on SAS planet."
currently i am using virtual GPS application to simulate the GPS data.
and receive this simulated data in SAS planet using virtual serial port.
the SAS planet displays the GPS track in dark grey color.
Is it possible to change the color of GPS track in real time......
when i stop the serial port data or disconnect the GPS receiver in SAS planet and then add the track to database,
then i am able to change the color.
But in real time i am not able to change it
Is there any option to change color in real time...????
Regards
zazu
adding more than one GPS
Сообщение zazu » 06 ноя 2020, 18:31
HI everybody
is it possible to connect and display data from more than GPS simultaneously using SAS planet software
Regards
Zazu
zazu
