Export to img or jnx for Garmin
Сообщение gvp9000 » 12 ноя 2019, 18:33
I have a Garmin DriveTrack 71 which doesn't show anything when i export to img or jnx from Sasplanet.
In the map list I can see the name of the map but I have an empty screen when i select it.
Anything I can do about it ?
ps
Birdseyes work fine.
gvp9000
Re: Export to img or jnx for Garmin
Сообщение Gma » 12 ноя 2019, 22:37
gvp9000 писал(а):I have a Garmin DriveTrack 71 which doesn't show anything when i export to img or jnx from Sasplanet.
Anything I can do about it ?.
You may need to redo the firmware of your device. In this case, you will lose the guarantee and there is no certainty that you will get the desired result.
If you make a raster img, then you need to meticulously observe the technology - it should work.
If you are unable to create a raster img readable by the device, tell the area, I can make a test card to check your device for reading.
Sorry, Google translated. )
gvp9000 (13 ноя 2019, 03:39)
Gma
Благодарил (а): 35 раз.
Сообщение gvp9000 » 13 ноя 2019, 00:19
the area is the:
38.400000 22.630000
38.400000 22.670000
38.370000 22.630000
38.370000 22.670000
very small area just for testing purposes.
thank you
gvp9000
Сообщение Gma » 13 ноя 2019, 11:29
gvp9000 писал(а):the area is the:
38.400000 22.630000
38.400000 22.670000
38.370000 22.630000
38.370000 22.670000
According to your coordinates. Visibility from 1.2 km to 300 m. On my 64th everything works.
Layers: OSM-topo + Google satellite.
https://yadi.sk/d/xV6I7FDzieAWPQ
gvp9000 (19 ноя 2019, 00:33)
Gma
