Download historical google earth imaginery
Сообщение gvp9000 » 31 окт 2019, 18:54
Is there a way to download historical google earth imaginery ?
When i select to view google earth maps in the current version of sasplanet an empty map appears !! What i'm doing wrong?
gvp9000
Re: Download historical google earth imaginery
Сообщение QuickBird » 02 ноя 2019, 10:47
Well there is always a way to everything so they say. The thing with Google earth is that the get links have been down for quite a long time. It is due to the "base part of request URL" you find under Settings / Map Settings / Internet. In that same dialog you can change the Map Version knowing that for google satellite is 855.
It is found in this thread.
viewtopic.php?f=12&t=989&start=1230
This is the section for google earth.
viewforum.php?f=12
You can translate here
https://translate.yandex.com/translator/Russian-English
To fix you will have to fiddle in the Get script, in the url or in the version part of the URL. I submit my apologies, svidanya.
I include zmp for Planet where you can request older versions in low res.
Planet.rar
QuickBird
Благодарил (а): 9 раз.
