[Request] Better Placemark manager
Сообщение caddis » 26 мар 2019, 00:26
A kind request for the developers of the SASPlanet.
After I added many palcemarks, thousands of paths, all with descriptions, links,…the file marks.~sml has grown up to 80 Gb.
My request: is it possible to make that SASPlanet manages the placemarks not with only two file ( Marks.~sml and Categorymarks.~sml) , but with many files inside a folder?
(In the same way of zmp in maps folder).
So that to add placemarks or paths, one can just put the files into the folder. If no possible to add directly KMZ, KLM or GPX, at least, to create many SML file instead of only one.
In this way, it is easy to share placemarks and paths with friends, just adding only the news files into the folder.
Also to keep the original icons, because now, importing KMZ files, only one type of icons is possible, even if they are different types of placemarks (camping, spring, cave, ...).
The second request is to see elevation profile (DEM) of the paths.
Thanks to all in advance
caddis
Благодарил (а): 12 раз.
Re: [Request] Better Placemark manager
Сообщение Tolik » 26 мар 2019, 10:21
On top of Placemark Manager you can see drop-down list of databases and 3 icons - add/edit/delete database.
So yes, you can create many SML files. But better switch to SQLite3 database, it's more suitable for large volumes.
caddis (28 мар 2019, 00:58)
Сообщение caddis » 30 мар 2019, 01:32
Tolik писал(а):On top of Placemark Manager you can see drop-down list of databases and 3 icons - add/edit/delete database.
Thank You Tolik,
I did not know this useful function!
About elevetion profile among properties of the paths? :)
caddis
