What Is Wrong When Black Areas Come?
Сообщение abrogard » 03 дек 2018, 23:44
I suddenly find some black areas where there should be houses.
Why is this?
Under the red track line:
https://imgur.com/a/3tdJJjz
abrogard
Re: What Is Wrong When Black Areas Come?
Сообщение vdemidov » 04 дек 2018, 21:23
As i understood. This is Previous Selection that you use for Selection Manager. You can disable it in menu View\Previous Selection
За это сообщение автора vdemidov поблагодарил:
abrogard (06 дек 2018, 03:51)
Благодарил (а): 191 раз.
Сообщение abrogard » 04 дек 2018, 23:11
Hi. Thank you for that. It was enabled, you are right. I disabled it but the picture has not changed.
I exited the program and opened it again but that didn't help.
Perhaps the image needs refreshing? I don't know how to force a refresh.
abrogard
Сообщение vdemidov » 06 дек 2018, 11:17
abrogard писал(а):Hi. Thank you for that. It was enabled, you are right. I disabled it but the picture has not changed.
Maybe this is polygon. Press "Hide All Placemarks" on the toolbar.
Сообщение abrogard » 07 дек 2018, 03:02
Thanks. Tried that but it didn't help.
I went to google earth and I found exactly the same thing.
Screenshot: https://imgur.com/a/8pE59mh
So it looks like it is a google earth thing not a sasplanet thing?
Very coincidental it happens across the road from my house.
abrogard
Сообщение Tolik » 07 дек 2018, 10:31
I still don't understand what are you talking about.
Parasite (09 дек 2018, 20:18)
Сообщение vdemidov » 07 дек 2018, 12:38
Tolik писал(а):I still don't understand what are you talking about.
As I realize now, I also haven't understood nothing.
Сообщение abrogard » 07 дек 2018, 14:53
Me?
You don't understand me?
I ask: Why the black areas?
First I think it is SASPlanet problem.
Now I find it on Google Earth so I think it is Google Earth problem.
I gave you a link to a picture so you can see what I mean: https://imgur.com/a/8pE59mh
The black areas in that picture should not be there. There should be houses and roads.
Somewhere around 35 08 04 S
139 17 34E
see if you get the same thing from SASPlanet and from Google Earth as me?
Last week it was okay. This week: black.
abrogard
Сообщение Tolik » 07 дек 2018, 16:15
No, I don't see any black areas on your screenshots.
Anyway, if you see the same on Google Maps and SASPlanet - perfect, that's the purpose of SASPlanet to show you exactly the same.
Сообщение abrogard » 08 дек 2018, 00:10
Oh, alright. Not 'Black' but very dark. Those rectangles running north east.
It is all my mistake. Those areas are grassland. They should, they do, look like that.
I was thinking they should be houses and roads. I was wrong. They are not.
All my mistake. Sorry.
abrogard
