Convert SAS.Planet Cache to GeoServer Cache
Сообщение omidi » 21 июн 2016, 09:55
Hi
Is there any way (or tool) to convert SAS.Planet Cache to GeoWebCache Cache?
Currently I export SAS.Planet Cache to mbtile and then use mbtile as a source for GeoServer integrated with GeoWebCache. but it is very time consuming process and don't work for large area.
http://geoserver.org
http://geowebcache.org
omidi
Re: Convert SAS.Planet Cache to GeoServer Cache
Сообщение zed » 21 июн 2016, 10:42
Do you have any description about supported cache formats? Is it support TMS format? SASPlanet can store tiles directly in this format or you can convert/export tiles from existing cache to this format.
Сообщение omidi » 22 июн 2016, 17:02
Hi
I search for additional info but the spec of structure not describe. the only thing I find is this:
Starting with version 1.8.0, there are two types of persistent storage mechanisms for tiles:
File blob store: stores tiles in a directory structure consisting of various image files organized by layer and zoom level.
S3 blob store: stores tiles in an Amazon Simple Storage Service bucket, as individual “objects” following a TMS-like key structure.
from here: http://geowebcache.org/docs/current/configuration/storage.html
this is the structure of cache directory of geowebcache:
the top level directory name base on projection and zoom level. but I'm not sure about others.
gwc
+---EPSG_3857_01
|   \---0_0
+---EPSG_3857_04
|   +---0_0
|   +---0_1
|   +---1_0
|   \---1_1
+---EPSG_3857_05
|   \---2_2
+---EPSG_3857_06
|   \---02_02
+---EPSG_3857_07
|   +---04_04
|   \---05_04
+---EPSG_3857_08
|   \---05_04
+---EPSG_3857_09
|   \---10_09
+---EPSG_3857_10
|   \---10_09
+---EPSG_3857_11
|   +---20_18
|   +---21_18
|   \---21_19
+---EPSG_3857_12
|   +---020_018
|   \---021_018
+---EPSG_3857_13
|   +---041_036
|   \---042_036
+---EPSG_3857_15
|   \---084_073
\---EPSG_3857_16
    \---084_073
omidi
