How made a map work on sasgis
Сообщение raistlin5 » 17 дек 2015, 17:39
Hi everyone, i've one map to work with Sasgis, but it seems there is a problem to link the data...
here is the cadastrezmp link to try...
two days i search a soution without result...
I've add the "cadastre.zmp" int the maps folder but, if i've the button into the layer ui, it seems to be impossible for it to download something...
http://ttmaps.free.fr/forums/download/file.php?id=388
thanks in advance
Cheers
Raistlin
raistlin5
Re: How made a map work on sasgis
Сообщение Tolik » 18 дек 2015, 18:18
Hi,
Unfortunately I did not understand anything.
Please just write what map do you need.
Сообщение Ivan30 » 19 дек 2015, 08:51
Я понял, что чувак сляпал zmp, карта не грузится, сам zmp по ссылке
raistlin5, I cant open .zmp from mobile, which service do you want to download? Give url, please
Ivan30
Благодарил (а): 60 раз.
