Some suggestions to the new version
Сообщение MontoyaSat » 19 июл 2015, 15:37
Maybe some interesting proposal and will appear in the new version of the program
1: Cache settings
It is now possible to set different paths to a type of cache
D:\cache_gmt\
E:\cache_GE\
F:\cache_dbv\
I would need to adjust the way they were for map resources
D:\cache_gmt\AtlasOrto\
E:\cache_gmt\Googlesat2015\
F:\cache_gmt\Both\
easier to back up smaller units as one large container (300GB)[/size]
2: New Cache type Z,X,Y
The easiest way to use the MOBAC cache in SAS. No further conversion is needed, etc.
when exporting MOBAC cache is created Address structure
the same tile in Global mapper tiles
I used for all maps "Global mapper tiles" cache in SASPlanet
I have to additionally convert MOBAC cache
then do I look under GMtiles
3: Geotag photos in SASplanet
SAS currently can import JPG with GPS exif. why did not Geotagging?
Geotag the photos to Panoramio I use GeoSetter (its development has ended)
SASPlanet has a larger selection of maps and quality
Geosetter has only one and each time the map is loading from the Internet
MontoyaSat
Re: Some suggestions to the new version
Сообщение zed » 19 июл 2015, 15:58
0. Use Bugtracker for propositions
1. You can set absolute path to cache folder in map settings (Ctrl+Alt+P) or you can use symlinks: https://en.wikipedia.org/wiki/Symbolic_link
2. Already implemented in Nightly builds
Сообщение MontoyaSat » 19 июл 2015, 20:22
I forgot to check the Nightly builds. in the latest stable version still could not set "absolute path cache"
I would have spared writing
Bugtracker used for "Geotag photo"?
I can there write in English as it's in my 3 point?
MontoyaSat
Сообщение Ivan30 » 19 июл 2015, 20:42
MontoyaSat писал(а):I can there write in English as it's in my 3 point?
yes. you can
Ivan30
Благодарил (а): 60 раз.
Сообщение MontoyaSat » 19 июл 2015, 21:49
Bugtracker Login throws me an error (I used login forum)
"Your account may be disabled or username / password you entered is incorrect."
You need to create a new account or do not have permission?
MontoyaSat
Сообщение zed » 19 июл 2015, 21:51
You need to create a new account for Bugtracker.
Сообщение MontoyaSat » 19 июл 2015, 21:59
zed писал(а):You need to create a new account for Bugtracker.
I suspected it
Thanks
MontoyaSat
