Exporting Google Earth
Сообщение PhilR » 13 апр 2015, 01:09
Hello I am in Australia and have been using SAS Planet for some time, it is fantastic and thankyou to all the originators and contributors.
I followed the post by ramissen "Can't get Google earth working" and have been able to get it all working in SAS - thankyou this has been very helpful and it is fantastic.
Using Selection Manager I am now trying to Download this image but when I click on "Map" I do not see an option for Google Earth. Which option do I use?
Is there a way to download this image and then I wish to Export it as a KML as I have done many times before using options for other like Arc.Gis Imagery.
Thank you very much. Phil
PhilR
Re: Exporting Google Earth
Сообщение zed » 13 апр 2015, 10:38
PhilR писал(а):I am now trying to Download this image
It's impossible by design. You should use GE itself to download images to cache (try this) and then you can use SAS to see them.
Of course, you can ask someone to do it for you: viewtopic.php?f=26&t=1378 + viewforum.php?f=58
