Movable Placemarks and polygon marks
Сообщение dukenuke » 18 ноя 2011, 23:48
Hello,
it is possible to build in the function, to move placemarks and polygon marks on the map per drag and drop? I need it for a custom map with changing placemarks.
I mean like the function in google maps for moving marks.
Thanks
dukenuke
Re: Movable Placemarks and polygon marks
Сообщение Tolik » 19 ноя 2011, 09:14
There is a feature request about placemarks: http://sasgis.org/mantis/view.php?id=138
Polygon points are movable now, not the whole polygon.
Сообщение dukenuke » 19 ноя 2011, 12:59
That' s right. I found this function, but i think about dragable marks in the map. it is possible, to bind the google maps api (i think its a js script) to the program.
Sorry for my bad english, i'm from Germany
Thanks
Walter
dukenuke
Сообщение Tolik » 19 ноя 2011, 17:51
If I understood you right you'd like to edit placemarks by dragging it. This feature is requested but not implemented so far. That means it is currently impossible, it will be possible as soon as developers create the necessary code.
It is impossible to bind the google maps api.
Sorry for my bad english, i'm from Russia :D
Сообщение dukenuke » 20 ноя 2011, 13:26
Thanks,
so i have to wait for the next version,like waiting for christmas :lol:
dukenuke
