How to create Garmin BirdsEye JNX maps
Сообщение bogi » 17 янв 2011, 22:09
For owners of Garmin devices with BirdsEye support: Colorado, Oregon, Dakota, GPSMAP62, GPSMAP78 and EDGE 800.
BirdsEye JNX format was decoded. Now users can create their own JNX maps from georeferenced images. JNX format overcomes the restrictions of Garmin Custom Map KMZ format, which are max. 100 JPG tiles of max. size 1 megapixel. Generally, Garmin units provide better performance with JNX maps than with KMZ maps.
SASPlanet users can create JNX maps from SASPlanet tile storage of type "Google Maps Tiles". Author of MAPC2MAPC created free tool MOBAT2JNX, which is able to convert tile storage of this type into one JNX file. More information and download: http://www.the-thorns.org.uk/mapping/help/jnx.html.
MOBAT2JNX is command line tool. Usage: mobat2jnx <path_to_GoogleMapTiles> -sas
Example call:
D:\mapy\APPS\MOBAT2JNX>mobat2jnx G:\mapy\test -sas
G:\mapy\test
levels=3
6 tiles at level 13
20 tiles at level 14
63 tiles at level 15
6 tiles written at level 13
20 tiles written at level 14
63 tiles written at level 15
Done
The directory <path_to_GoogleMapTiles> should contain zoom level subdirectories of the tile storage, for example z13, z14, z15.
The result is one file jnx.jnx. Rename it as you wish, JNX suffix should be retained.
To use user generated JNX files in Garmin devices, firmware should be patched. Please find basic information and the firmware patcher here: http://whiter.brinkster.net/JNX.html
JNX files have to be copied into directory \Garmin\BirdsEye (prefferably on SD card).
За это сообщение автора bogi поблагодарил:
sectoidik (10 дек 2011, 00:43)
bogi
Благодарил (а): 4 раз.
Re: How to create Garmin BirdsEye JNX maps
Сообщение Papazol » 17 янв 2011, 22:52
bogi писал(а):Для владельцев следующих устройств Garmin с поддержкой BirdsEye:
Colorado, Oregon, Dakota, GPSMAP62, GPSMAP78 и EDGE 800.
BirdsEye JNX формат декодирован. Теперь пользователи могут создавать свои собственные JNX карты из любых географически привязанных картинок. JNX формат обходит ограничения формата Garmin Custom Map KMZ, который имеет максимум 100 JPG тайлов максимального размера 1 мегапиксель. В основном устройства Garmin обеспечивают лучшую производительность с JNX картами, чем с KMZ картами.
Пользователи SASPlanet могут создать JNX карты из тайлов SASPlanet, сохранённых в кэше типа "Google Maps Tiles". Автор программы MAPC2MAPC создал бесплатную утилиту MOBAT2JNX, которая способна конвертировать кэш указанного типа в один JNX файл. Подробности и скачать: http://www.the-thorns.org.uk/mapping/help/jnx.html.
MOBAT2JNX - инструмент командной строки. Использование: mobat2jnx <path_to_GoogleMapTiles> -sas
Пример использования:
G:\mapy\test
levels=3
6 tiles at level 13
Done
Директория <path_to_GoogleMapTiles> должна содержать субдиректории зумов, например, z13, z14, z15.
Результат - один файл jnx.jnx. Переименуйте его как хотите, расширение JNX должно остаться.
Чтобы использовать самодельные JNX файлы в устройствах Garmin, прошивка должна быть пропатчена. Пожалуйста, найдите основную информацию и патчер прошивки здесь: http://whiter.brinkster.net/JNX.html
JNX файлы должны быть скопированы в директорию \Garmin\BirdsEye (предпочтительно на SD карточке).
Сообщение metallizer » 19 янв 2011, 14:18
у кого-нибудь получилось создать jnx изи кэша sas?
во первых, программа не понимает пробелы в пути или путь в кавычках.
если же путь без пробелов, то лично у меня программа вылетает с ошибкой.
пишет следующее:
Using jnxscale=130.2084
c:\yasat
levels=3
0 tiles at level 14
0 tiles at level 15
0 tiles at level 16
0 tiles written at level 15
0 tiles written at level 16
а потом пишет о переполнении - System.OverflowException в модуле make_jnx()
проверял под win 7 x64 и win xp x32
похоже путь к тайлам все же некорректно определяется, т.к. результат - 0 tiles.
metallizer
Сообщение bogi » 19 янв 2011, 20:52
metallizer, do you have your cache in the format Google maps tiles? mobat2jnx doesn't work with the cache type SAS.Planet.
If your cache is in other format, you can export selected map area as Google maps tiles cache. mobat2jnx has limit of max. 48000 tiles. You can try the tool with small cache export.
Your directory c:\yasat should contain subdirectories z14, z15, z16.
Please do not forget to add the second command line parameter -sas
bogi
Сообщение metallizer » 20 янв 2011, 00:27
oppps! my cache type was a SAS.Planet. :oops:
Thanks for detailed instuctions! :D
metallizer
Сообщение metallizer » 20 янв 2011, 01:19
found a bug:
c:\111\yasat\
levels=3
13500 tiles at level 13
7641 tiles at level 15
4314 tiles at level 16
900 tiles written at level 13
4314 tiles written at level 16
Done
metallizer
Сообщение bogi » 20 янв 2011, 02:25
metallizer, I have an explanation.
One user on gpsforum.sk found, that mobat2jnx uses the smallest area selection (or maybe the highest level area selection) across all levels. I think you became result only for area of your level 16. On the area of your level 16 you have no tiles of level 15 and only 900 tiles of level 13.
He solved that by adding one tile on each side (east, west, north, south) of his area of interest. They can be empty transparent tiles too.
It would lbe nice if author of mobat2jnx solves this issue. If you wish to contact him, you can find email address on the bottom of page http://www.the-thorns.org.uk/mapping/
bogi
Сообщение bogi » 20 янв 2011, 02:53
You can try the following workaround:
Rename z15 and z16 for example to 15 and 16. Run mobat2jnx. It will generate JNX only for level 13. Rename the resulting JNX for example as 13.JNX.
Then generate the 2nd JNX only for level 15 and rename it.
And the 3rd for level 16.
Then place all 3 JNX files into \Garmin\BirdsEye folder of SD card.
I hope this workaround should function well.
bogi
Сообщение metallizer » 20 янв 2011, 11:33
Thanks, I did so.
metallizer
Сообщение bogi » 21 янв 2011, 17:01
metallizer, new MOBAT2JNX version was released: http://www.the-thorns.org.uk/net/mobat2jnx.zip
You can call now (with all 3 levels z13,z15,z16):
mobat2jnx c:\111\yasat -sas -trim13
The result should be as you expected.
Additionally, the new version is able to set jpeg quality. For more details, see the readme file in the archive.
bogi
Сейчас этот форум просматривают: Google [Bot] и гости: 9
