SASmerge - superimpose more map layers
Сообщение bogi » 13 сен 2010, 22:03
I wished to create raster maps, consisting from a base map and more transparent layers. SAS.Planet enables to create map from one base map and one map layer only. I decided to create an add-on tool for SAS.Planet, which generates tile cache of merged base map and one map layer. Such tile cache can be subsequently used as base for adding another layer.
You can find more information about the merging process here: http://bogi.gpsforum.sk/documents/SASmerge_english.pdf
Download the SASmerge tool: http://bogi.gpsforum.sk/tools/SASmerge.rar
I understand and can read Russian, but it is very hard for me to write in Russian language. Feel free to answer in Russian language. :)
За это сообщение автора bogi поблагодарил:
Parasite (17 мар 2011, 23:40)
bogi
Благодарил (а): 4 раз.
Re: SASmerge - superimpose more map layers
Сообщение Parasite » 17 мар 2011, 23:40
bogi писал(а):I wished to create raster maps, consisting from a base map and more transparent layers. SAS.Planet enables to create map from one base map and one map layer only. I decided to create an add-on tool for SAS.Planet, which generates tile cache of merged base map and one map layer. Such tile cache can be subsequently used as base for adding another layer.
Well, that could be done even within SAS - by merging the layers one by one.
But of course the single operation will benefit the speed&productivity. You got my thanks. :)
bogi писал(а):I understand and can read Russian, but it is very hard for me to write in Russian language. Feel free to answer in Russian language. :)
That's not necessary - here are some "citizens of the World"© too :D
Сообщение Tolik » 18 мар 2011, 10:04
Parasite писал(а):Well, that could be done even within SAS - by merging the layers one by one.
Чё-то я не соображу как
Сообщение zed » 18 мар 2011, 11:00
А вы pdf-ку из первого поста проштудируйте. Дам всё доходчиво и с картинками.
Сообщение Tolik » 18 мар 2011, 11:11
zed писал(а):А вы pdf-ку из первого поста проштудируйте. Дам всё доходчиво и с картинками.
При чём тут описание SASmerge?
Я спрашивал, как сделать merging the layers one by one средствами САСпланеты?
Сообщение Parasite » 18 мар 2011, 13:28
Tolik писал(а):Я спрашивал, как сделать merging the layers one by one средствами САСпланеты?
for ($i=1; $i<число_слоев; $i++) {
   свести_сасом_с_наложением_слоя[$i];
   перенарезать;
   if (качество_результата < плинтус) {die "Апстену!!"}
Гимор конечно, но можно - если приспичит. За уменьшение чего топикстартера и оспасибил (хотя больше для отладки фичи спасибок, если честно). Хай гордицца.
Сообщение Tolik » 18 мар 2011, 13:34
Parasite писал(а): перенарезать;
А, это гемор...
Может хотелку оформить? Чтоб 2 слоя можно было сразу наложить? Или 3? Сколько может реально понадобиться?
Сообщение Parasite » 18 мар 2011, 13:56
Tolik писал(а):Сколько может реально понадобиться?
Очевидно что ровно столько, сколько данный САС нашел ZMP слоев при запуске и добавил к себе в список карт\слоев.
То есть весь список из слоев -> в склейку, где юзер и и отметит галочками. Правда надо будет как-то решать вопрос с порядком их следования\наложения...
Сообщение Tolik » 18 мар 2011, 14:02
А ещё лучше карту и все слои, включенные в данный момент -> в склейку!
Сообщение Parasite » 18 мар 2011, 14:09
Tolik писал(а):слои, включенные в данный момент
Ну это частный вариант общности, написанной выше. Выбор-то все равно будет из всех - на экране или при склейке.
А раз уж там есть выбор карты для склейки из всего списка - то и слои точно так же сделать, только выбор не одного по OPTION а нескольких по CHECKBOX. :)
